2023-Nov-03-R11.1a
Select ADT Intents for Triggered Diagnosis
Example: Select ADT "Ondemand Intent". Some intents are associated with ADT assets, which can be executed to address interface error issues. Then, we select the ADT for triggered automation and filter useful ADT intents to check and solve interface error.
- In the Intent field, click the
icon, then select ADT Intents.
- Click Select. In the Select Automation Data Table dialog, enter search keyword to find the proper ADT containing intent columns, then select the ADT "Ondemand Intent".
- Click OK.
