2023-Nov-03-R11.1a
Only Map Device with Alert or Success Status Code
  1. Enter the NI Edit Mode, then click the  icon and select Intent Settings.
  2. On the Intent Map and Data View tab, only select the Alert check box in the Data View area.
  3. Click OK. Then save the intent.
  4. Open the intent result on the map, and you will see that only the devices with alert status code are diaplyed.
