2023-Nov-03-R11.1a
Display Status Codes from Follow-up Intents Together
In actual use flow, the intent is often used with one or multiple follow-up intents defined inside. And the status codes of home intent and all follow-up intents can be displayed for you to view the execution results.
  1. Enter the NI View Mode to view the status codes. The number 227 is the sum of the alert status codes of home intent and all follow-up intents.
  2. Click this number and the Diagnosis Message dialog pops up. You can view the status codes by intent or by device.
  • Clicking the intent name can directly enter the NI view mode of the follow-up intent.
  • You can select the following three check boxes to view only the alert status codes, success status codes, or diagnosis messages.
  • Click a status code to enter the Diagnosis Details and Compare dialog. See Clickable Status Code for more information.
  • Up to 20 status codes at each intent/device level can be displayed; the rest can be viewed by clicking View More.
  1. You can also select a specific intent to view its status codes and the status codes of its follow-up intents.
