2023-Nov-03-R11.1a
Discover VMware NSX-V Networks
NetBrain can discover the following components of an NSX-V network via restful APIs and then build network topology based on the retrieved data.
  • NSX Managers
  • NSX Controllers
  • Logical Switches
  • Distributed Logical Routers
  • NSX Edges
Prerequisites: A user account with the Auditor role is required to enable NetBrain to discover an NSX-V network.
Information Note: This configuration for the NSX-V user role is required on the vCenter to which the NSX Manager is registered.
The main flow of discovering VMware NSX-V networks are as follows:
  1. Set Up API Server in NetBrain — define the required parameters to access 3rd-party systems via APIs.
  2. Discover NSX-V Network in NetBrain — discover the components of an NSX-V network via restful APIs, and then build network topology based on the retrieved data.
  3. Auto-Update NSX-V Data in NetBrain through Benchmark — execute a benchmark task to retrieve all data and build all components, including visual spaces and data views.
