2023-Nov-03-R11.1a
Define the Incident Message
Each ticket will:
  • Append a message to the corresponding Incident;
  • (Optional) Append a recommended Guidebook or Runbook template for the interactive troubleshooting.
Besides the text, you can insert data field from the category, built-in special fields ({Incident Type}, {source}, {category}, and {triggered time}), and hyperlink into the message.
To define a hyperlink, you define the label and URL. Besides the manual input, you can insert the data field and custom variable in both fields.
