2023-Nov-03-R11.1a
Define the Conditions for the Intent to be Triggered
The triggered condition defines when this Diagnosis will be executed. The following Example illustrates how to define triggered condition for intent-based triggered automation.
Example: You can select Application Check. All incidents belonging to this virtual incident type can trigger associated intents to run for diagnosis or mapping.
- Select the Incoming Incident Type or Virtual Incident Type to trigger this Diagnosis (Virtual Incident Type is selected in this example).
- Select Incident Type: Select an incident type to categorize incoming tickets, e.g., Application Check.
- (Optional) Define the filters.
- Select a data field of the Incident Type.
- Select an operator (contains, does not contain, matches, does not match, is not null).
- Enter a keyword.
You can combine multiple simple filters with the standard Boolean AND/OR operations.
