2023-Nov-03-R11.1a
Define Sub Table
The system supports defining sub table for you to filter the noise data from the base table. For example, analyze the route entries related to the critical application subnet in the device route table and ignore the changes of other dynamic routes. You can filter the rows by either keeping or removing the value at the specific columns routes (filtered by value), or keeping or removing the rows of the base table matching the conditions (filtered by condition), reducing the noise alert that may appear in diagnosis.
