2023-Nov-03-R11.1a
Creating a Device Group
  1. Click the start menu  and select Device Group.
  2. In the Device Group pane, right-click the My Device Groups node or the Public node and select New Device Group from the drop-down menu.
  3. Information Note: The device groups in the My Device Groups category are only accessible to you; the device groups in the Public category are accessible to all domain users.
  4. In the Device Group Properties dialog, enter the name and short description for the device group.
  5. Use one of the following ways to add devices or interfaces to the device group:
    • Adding static devices or interfaces to a device group
      1. Static Device:
        1. Click Static and select Static Device from the drop-down list.
        2. Specify the device scope by selecting Device Type, Device Group, or Site.
        3. Use to select devices (multi-select supported) and use to add all devices to the list.
      2. Static Interface:
        1. Click Static and select Static Interface from the drop-down list.
        3. Use to select interfaces (multi-select supported) and use to add all interfaces of that device to the list.
      3. If you want to add all interfaces in the data scope (a site/device group or a device type), you can click Table
Description automatically generated with medium confidence.
    • Adding dynamic devices or interfaces to a device group
      1. Click Dynamic Search and select Dynamic Search Device from the drop-down list. See Dynamic Search for further operations.
      2. Information Tip: A device group with dynamic devices or interfaces can be updated in a Benchmark task. See Benchmark Task Settings for details.
      3. Click Dynamic Search and select Dynamic Search Interface from the drop-down list. See Dynamic Search for further operations.
      4. Information Note: Dynamic Interface only supports Match and Do not Match for operation.
    • Excluding devices or interfaces from a device group
    • Click Exclude and select Exclude Device/Interface from the drop-down list.
    • Importing devices
      1. Click import.
      2. Select a .csv file from your local folder with the required device information (Hostname, Management IP, Vendor, Model, Interface, Interface IP). Here is a sample of the .csv file containing devices and interface:
      3. Click open.
  6. Click OK. The devices or interfaces are listed in the table.
    Information Tip: The created device group with the  icon in front only contains devices, and the group with the  icon contains interfaces, or devices and interfaces.
  7. To share your device group, right-click it and select Move. Choose a Public folder from Shared Device Groups that you would like to move to.
