2023-Nov-03-R11.1a
CLI Commands
If some types of device data are not covered in the previous step, you can add CLI Commands in the CLI Commands tab to
  • Collect the data and use them later
  • Keep records of historical data and compare them to monitor network changes
There are two ways to add CLI commands to Benchmark:
  1. Add CLI commands by device type
    1. Enter the CLI commands in the Enter Command box
    2. Select the device types from the drop-down list
    3. Click Add.
  2. Load CLI Templates
    1. Click on 'Load CLI Templates'
    2. In the Load Templates window, select the CLI Template from the list on the left
    3. (Optional) Narrow down the CLI commands to be loaded from the list on the right
    4. Click Add.
