2023-Nov-03-R11.1a
Archiving a Network Change Task
When a change task is completed, you can archive it. Once archived, a change task cannot be edited or deleted anymore. But you can still open and view the historical results of it.
- Open the target change management task, click the
icon and select Archive Change from the drop-down menu.
- In the Archive dialog, click Archive.
