Logo
Use ADT in Diagnosis
You can use the Automation Data Table (ADT) to define diagnosis in intent, for example, handle ADT Update and ADT-based follow-up intent, and loop ADT to get the multi-line text for device config-let compliance check.
The two use cases are as follows:
  • Add ADT Row
  • Update and Clean ADT Based on Time
Use Case of Return Value Add ADT Row
