Set Maximum Displayed Lines in One ADT Row
In some cases, the texts in a table cell are multiline text. To save space and display neatly arranged data, you can set the maximum lines displayed in a table row, then you can click the entry to check the full contents. This setting is configured from the Table Menu.
- Select Table Settings from table menu.
- In the Advanced Settings for ADT and Each View section of the pop-out dialog, input the maximum lines of text displayed.
Note: The default value is 1.
