Retrieve Device Data
You have two methods to obtain the device data:
- CLI: Use CLI commands to retrieve data.
- Config: Retrieve data from device configurations without entering command.
Example: Use CLI command to retrieve device data.
- Select or input a CLI command.
Click the
icon to set the data source. You can set the data resource as Live data/Cached data/ADT dataset.
- If cached data is selected, the latest data will be displayed, which contains the current baseline or NIT decoding results.
Use ADT dataset option to use historical data from dataset.
Click Retrieve.
After successfully retrieving the data, you can select a pair of device and command to view the data.
