Reset to Clear Previous Data
In some cases, you may have created a temporary intent, but the intent turns out to be unsatisfactory. In this scenario, you can firstly clear all previous settings, then repeat the auto intent flow to create a new intent.
Click Reset at the upper right corner to clear the previous settings in Auto Intent as shown below.
After the reset operation:
- The previous data are cleared.
- The data view generated by the current auto intent and applied to the map is cleared from the current map.
- The two panes of Auto Intent return to initial status.
- In the left pane, the device list will not change, and all devices are checked.
