Overall Health
You can specify the Data View Template used for Overall Health View:
| Field | Default Value | Description |
| Data View Template | Built-in Data View Templates/Overall Health View | Define the Data View Template used for Runbook Overall Health View node and for Overall Health View option from the right-click menu on map. |
