Open Seed Intent
This topic described how to check seed Intent linked to the intents in the ADT intent column. You can see the seed intent in the NI Editor. If there is no seed intent for the current intent column, like in the case of a manually created column, a message will pop-up to let you know.
Follow the steps to check the seed Intent linked to the Intent in the ADT Intent column.
- Place your cursor over the Intent column and click
. - Click Open Seed Intent in the menu, then the intent will open in Edit mode.
Note: When the ADT intent column is created by the Intent Templates via Other ADT method, the Open Seed Intent function is not available. |
