Network Security
You can encrypt a variety of sensitive data in the configuration file of each device and on the user interface using Enable Encryption for Sensitive Data option.
| Check Box | Default Value | Description |
| Enable Encryption for Sensitive Data | Enabled | If this check box is not selected, the encryption for sensitive data is disabled and you cannot select either of the following two encryption methods. The sensitive data include:
| Mask Data at Back-end (no traceback) | Enabled | This method allows you to replace the matched texts both in the database and UI with asterisks (***). |
| Only Mask Data on User Interface | Disabled | This method allows you to replace the matched texts displayed in the UI with asterisks (***). Note that the corresponding texts are not replaced in the database. |
Note: Any changes to the settings will take effect starting from the next discovery and benchmark task. |
