Modify Diagnosis Manually
After adding the diagnosis with a template, you can further modify it manually.
  • Variable: You can select all variables of the current parser. If it is a table variable, all its columns will be listed so that you can select either a table or a table column.
  • Diagnosis: Three types of diagnosis are provided: Compare with Baseline/Last/Customized Value.
    Information Note: When you select a table variable, two types of diagnosis are provided: Compare with Baseline and compare with Last. You can also refine the output settings, such as the table key, status code, and the number of modified entries to display.
    A screenshot of a computer  Description automatically generated
The node content on the Define Logic pane differs depending on the diagnosis type.
  • Compare with Baseline: The logic is predefined, allowing you to refine the diagnosis message when necessary.
  • Compare with Last: The logic is predefined, allowing you to refine the diagnosis message when necessary.
  • Compare with Customized Value: In addition to the diagnosis messages, you can select an operator and either choose a variable or input a value for comparison. For example, you can adjust a threshold value.
