Mapping Devices by Site
A site map is a system-generated map, while Draw Devices on Map gives you the freedom to add devices in a specific site to any map.
  1. Click Site on the taskbar to open the Site pane.
  2. Point to a leaf site and click the  icon to select Draw Devices on Map from the drop-down menu. The devices will be drawn on the current map or a new map if no map is opened.
