Map Intent
Users can associate an intent with a map to document the key design or the primary troubleshooting steps. By embedding an intent in a map, users can have the map and intent work side-by-side and promote a simple power-user workflow: Create an intent for a map and then use the intent while using the map.
Note: A map can only have one Map Intent. |
