Map a Historical Path
To map a path with the latest calculation result, do the following:
- Click Path on the taskbar to open the Path Browser.
- Right-click a path and select the Draw Latest Path on Map option from dropdown.
Tip: To map a path with historical calculation results, click the hyperlink of numbers in the History column, right-click an entry according to the start time of calculation and then click Open Path in Map.
Tip: To recalculate the path instantly, you can right-click the path and select Calculate Live Path or Add to Path Calculation Bar to calculate the path.
