Manage Tenants
Users with the privilege of system management can view and manage the tenants in the system.
To view and manage the tenants in the system, do the following:
  2. On the System Management page, select the Tenants tab. The tenants created in the system are listed on the page.
  1. Select a tenant and select Edit from the drop-down menu.
    Table
Information Tip: You can select Delete from the drop-down menu to remove a tenant from the system.
  1. Define the settings in the pop-up window:
  • Basic Information: Specify a tenant name and enter descriptions for the tenant.
  • License Allocation: Allocate network module license and function module license to the target tenant.
  • Assign Users: Assign users for this target domain. For each assigned user, you can set the user privilege by enabling the Tenant Access or Tenant Admin check box.
  1. Click OK to save the settings and create the tenant.
