Manage Intent Dashboard
Intent dashboards will be managed along with universal dashboards in the Dashboard Manager. The icons of the dashboard will differentiate between universal dashboards and intent dashboards.
To manage a dashboard, select an intent dashboard and click
to select one of the following options:
- Open: Select to display the intent dashboard.
- Save As: Use this option to create a new intent dashboard with the same content as the selected intent dashboard.
- Rename: Use this option to modify the name of the intent dashboard.
- Move To: Choose the option to move the selected intent dashboard to other folder.
- Delete: Click Delete to delete the selected intent dashboard.
To manage any selected folder, select a folder and click
to select one of the following option:
- New Folder: Select to create a sub folder under the selected folder.
- New Universal Dashboard : Use this option to create a new universal dashboard under the selected folder.
New Intent Dashboard : Use this option to create a new Intent dashboard under the selected folder.
- Rename: Use this option to modify the name of the selected folder.
- Delete: Click Delete to delete the selected folder.
- Import: To import a dashboard into this folder.
