Golden Engineering Studio
Golden Engineering Studio (GES) is for users to maintain consistent design and prevent configuration drifts to avoid security vulnerabilities, compliance issues, and outages across the network. With GES, users can discover the network design (Golden Config) by reverse engineering and create thousands of automations without any code. It includes three main components:
  • Golden Config: Defining, discovering, managing, and verifying the network design. It uses two methods, reverse engineering and forward engineering, to discover the Golden config design in your network.
  • Golden Feature: Model the critical design assets for your network and can be used as the base to further build the intent automation (Golden Intent).
  • Golden Intent: Simplify the creation process of member intents for Golden Features so that users do not need to learn multiple concepts and complex logic of NI and ADT, reducing the learning curve.
