Featured Management Privileges
When creating a user account, you can authorize the featured management modules to this user by selecting System Management, User Management, or both.
The detailed differences between the two options are described in the following table:
Management Category | Featured Management Module | System Management | User Management |
System Management Page | System Home Page, including Usage Report | √ | |
License | √ | ||
Tenants | √ | ||
User Accounts | √ | ||
Front Server Controllers | √ | ||
Email Settings | √ | ||
Advanced Settings - Global Session Timeout | √ | ||
Advanced Settings - Others | √ | ||
Resource Update | √ | ||
Task Manager | √ | ||
API Adapters | √ | ||
Script Manager | √ | ||
Deployment Status | √ | √ | |
Service Monitor | √ | √ | |
Tenant Management Page | User Authorization | √ | |
Domain List | √ | ||
Multi-vendor Support | √ | ||
Misc Configuration | √ | ||
GDR Data Configuration | √ | ||
API Manager | √ | ||
Interface Type | √ | ||
Platform Management | √ | ||
Topology Link Style | √ | ||
Advanced Settings - Upload Visio Template | √ |
