Executing Benchmark After Network Change
To verify the network change, it is recommended to collect the network data after the network change and use the data for further comparison.
- Click the Benchmark After node.
- In the Benchmark After pane, click the
icon to customize devices and define the data type. The predefined devices, CLI commands, and data types are used by default. - Click Run to benchmark data.
Tip: If you select the Auto update all selected data in Current Baseline check box, the configuration files stored in the Current Baseline will be overwritten with the retrieved data. - Click the Results tab and select a device to view its results.
- Click the Execution Log tab and select a device to view its logs.
