Edit Observability Dashboard
  1. Click the start menu, and select Intent-Based Automation> Observability Dashboard.
  2. Select and open an existing observability dashboard.
  3. Click and select Edit Dashboard from the drop-down menu.
     A screenshot of a computerDescription automatically generated
  4. In the edit mode, make changes per your requirements.
  • Summary Chart cannot be deleted or edited.
  • Result Detail Chart/Top-N Chart/Geo-Map Chart can be added/deleted/edited.
  1. If you make any changes to the chart settings, click Apply to apply the changes.
  2. Click Save to save the changes.
  3. Click Close to exit the edit mode.
    A close-up of a signDescription automatically generated
