Dry-Run
Ansible supports the Dry-run mode to simulate the Ansible node execution process. Clicking the Dry-run hyperlink will generate Dry-run Log containing Dry-run results.
The terminate button can be used to force stop the Ansible task running on the Linux server. However, it is not recommended to perform a force stop unless it’s necessary (such as an un-responding process), as it may cause an unknown system failure.
Information Note: Dry-run on multiple Ansible agents is not supported.
