Document Path
Document all key applications while the network is working, including inputting all endpoints and gateways of these applications into the system via importing a CSV file or manually defining them through GUI; discover their paths while the network is working properly; define the Network Intents (NI) for these applications.
You can document a path via path description, note, reference map, and path NI.
