Resolve Devices Discovered by SNMP
SNMP Configuration Devices refer to the devices that are accessed by using SNMP and cannot be accessed by Telnet/SSH. There might be the following reasons:
- Telnet/SSH is not supported for these devices, and only SNMP is allowed.
- The credentials configured in the Network Settings are incorrect.
- The Front Server cannot access these devices using Telnet/SSH due to firewall rules or ACL.
Note: The configuration files of the devices discovered by SNMP are incomplete. Consequently, some functions may not work as expected. It's recommended to resolve the devices first. |
The table lists the SNMP Configuration device reasons and their solutions depending on the possible causes. Contact NetBrain Support Team for further assistance.
| Type | Description | Solution |
| Ping Failed, No Try CLI | The IP addresses that NetBrain cannot Ping and do not try to access via CLI. | Rediscover the IP addresses. |
| Don't Support CLI | The IP addresses that don't support Telnet/SSH access. | Check whether the corresponding device type supports Telnet/SSH access. 1.Navigate to Tenant Management > Muti-vendor Support > Device Type. 2. Edit the device type to confirm whether the Telnet/SSH is checked in Supported Operation. |
| CLI Connection Failed | The IP addresses that NetBrain fails to access via SNMP and Telnet/SSH. | Check whether the network delay leads to a timeout. |
| CLI Non-privilege Login Failed | The IP addresses that NetBrain fails in Non-privilege Login. | Check whether the Telnet/SSH Login credentials are incorrect. |
| CLI Privilege Login Failed | The IP addresses that NetBrain fails in Privilege Login. | Check whether the Privilege Login credentials are incorrect. |
| CLI Configuration Retrieval Failed | The IP addresses that NetBrain can log in via Telnet/SSH but fails to retrieve CLI configurations. | Check whether the configuration is too large to retrieve. |
| CLI Configuration Updated Failed | The IP addresses that NetBrain can retrieve CLI configurations but failed to update Global Data Repository based on the CLI configuration. | Check whether the driver is parsing the devices correctly. |
| Others | The IP addresses that NetBrain fails to fully access due to other factors except for the above situations. | Discover the IP addresses. |
