Discover VMware NSX-T Networks
With NetBrain, you can quickly visualize and understand a VMware NSX-T Network from the following aspects:
- Automatically discover the information of NSX-T components such as T0/T1 Gateways, Segments, N-VDS Transport Nodes, Edge Nodes, and so on. This enriched data is helpful to better understand the network's configuration, dependencies, and potential bottlenecks.
- Map feature can visualize the NSX-T infrastructure, such as the topology of Logic Components like T0/T1 Gateways, Segments and Virtual Machines. This feature provides a comprehensive view of the network topology, enabling users to quickly identify and troubleshoot potential issues in their NSX-T environment.
- Path feature can calculate the AB path between the two endpoints inside or outside the NSX-T networks. The path calculation can also support checking DFW Policy, Gateway Policy, NAT and Load Balancer, which can help analyze the security, traffic flow, or load balancing quickly and visually.
- More data information by applying data views driven by API parser.
Example: A Visualized L2 Topology Map of Logical Components under one NSX-T instance.
Example: A Visualized L2/L3 Topology Map of 3-Tier NSX-T Network.
L3 Topology L2 Topology
Example: A Visualized L2 Topology Map of NSX-T Underlay Network by N-VDS
Example: A Visualized L3 Topology Map of NSX-T Underlay Network by N-VDS
Example: A Visualized L3 Path for NSX-T Components
Note: DFW Policy is checked in APP1 Virtual Machine showed in marked path detail logic. |
Example: A Visualized Load balance Path showing the path go through the Server behind the Virtual Service IP.
Example: A Path showing the packet is dropped by DFW policy in the Source Virtual Machine Server.
Example: A Path showing the packet is permitted by Gateway policy checking in the T-1 Gateway.
