Device Group Pane
To view the device group functionalities and features, open any of the device group as follows:
  1. Click the start menu  and select Device Group to open the Device Group Pane.
    Information Note: You can search subfolders and device groups under a type of device group, and double-clicking a item in the search results can locate it in the left pane.
  1. Critical operations we provide for Device Group Folder.
Information NoteSystem Device Groups and Media are system-generated device groups that cannot be modified by end users.
  • Create New Folder
Information Note: System Device Group and Media are system-generated device groups that cannot be edited by end users.
  • Rename a Device Group Folder
  • Move the selected folder to another folder.
Information Note: This operation is unavailable for folders System Device Groups (if any) and Media (if any). For Policy Device Group, folders in this category cannot be moved to other categories, like Shared Device Groups or My Device Groups, but can be moved to another folder inside this category.
  • Delete selected folder:
  1. Key operations for Device Groups.
    • Edit selected Device group.
Information Tip: To edit the device group, please see Creating a Device Group for more details.
Information Note: This operation is unavailable for device groups in System Device Groups and Media.
  1. Move selected Device Group to another folder
Information Note: This operation is unavailable for device groups in System Device Groups (if any) and Media (if any). For Policy Device Group, device groups in this category cannot be moved to other categories, like Shared Device Groups or My Device Groups, but can be moved to another folder inside this category.
  • Delete selected Device Group
You can delete the devices in the device group from the domain by checking the checkbox above.
  • Open Group Map, Draw Devices on Map, Draw Group on Map
For the 3 functions above, please see Opening a Device Group Map and Mapping Devices and Device Group for more details.
