Defining the Benchmark After Node
The Benchmark After node is used to collect network data after the change is implemented, thus verifying if the change has been deployed successfully. Additionally, the benchmark results will be compared with the data collected in the Benchmark Before node.
- Select the Benchmark After node in the runbook.
In the Benchmark After pane, define the following settings:
Click the the
icon to select the target devices for the benchmark.
Add CLI commands using either way.
Click the the
