Define Task Variable
Enter the NI Edit Mode, and click the
icon and select Task Variable.
On the Task Variable tab, click Task Variable Manager.
Note: Only the users with the Shared Resource and File Management privilege can view the entrance of Task Variable Manager. - In the Task Variable Manager, define task variables and manage them.
You can add a new task group to classify your task variables. Or select Add Task Variable in the drop-down list of an existing task variable group to add a task variable under this group.
In the Add Task Variable dialog, define the task variable, such as name, type, and default value.
Click OK.
