Define Replication Logic
An intent is always associated with one or multiple devices. The intent diagnosis can be replicated to a set of target devices using replication settings, this scalable way is easy-to-do. To access and define the Replication Logic is:
  1. Open a intent and switch to Edit mode.
  2. From the  menu and select Replication Settings.
  3. By default, the window will open in Intent Replication Logic Settings tab. The settings are organized into the following categories:
    1. Intent Replication Logic Settings: Define the replicated intent name, target device qualification, and command qualification.
    2. Advanced Settings: Specify critical variables, device macro variables, signature variables, and other matching settings between the seed and target devices.
    3. Test Replication: It allows you to select a batch of devices and perform test operations.
See Also
