Defining the Change Node
The Define Change node is to define target devices and commands to be executed on the target devices.
- Select the Define Change node in the runbook.
In the Define Change pane, define the following settings:
Click
to select the target devices. If the Network Change Task is related to a map, all devices on the map will be selected.
Tip: You can use variables to hide the sensitive data of commands, and only users with specific privileges can view the data. See Using variables in command for details . - Click Config Change and enter the commands you want to execute on the target devices.
All Devices and click Append to add the command to all device.
Tip: You can click Load Template and select a predefined configuration template. To create a new configuration template, see Managing Configuration Templates for details.
Note: You need to define the new variables before proceeding. Click the new variable and define it in the pop-up window.
See Shared Device Settings for more details.
Tip: Point to a device and click
to select more options: Remove Device, Shared Device Settings, Change Management Login, View Configuration File.
Example: Enter the commands to encrypt a password.
Codeconfig t
password encryption {{}}
end -
Click
Tip: To clear the applied change command to all devices, click All Devices and click Overwrite.
Tip: To cancel a specific change, click the Rollback tab and enter the rollback commands. |
