Default Data Source
You can set a default source for a Qapp so that you will not have to reselect the data source each time when you run the Qapp.
To specify the data source for a Qapp:
  1. On the Execution Flow tab, click the icon.
  2. In the Run Options window, enable the required data sources and define the default one for the Qapp:
  • Current Baseline — the latest device data saved in the system.
  • Live Regularly — log in to the device to retrieve live data regularly based on the customized frequency. You can check the Repeat checkbox and enter a number to set the execution times for this Qapp.
  • Live Once — log in to the device instantly to retrieve live data for once.
  • History time period — select a time period.
  • History time point — select a time point.
