Configuring Privilege Login
The privilege login credentials refer to the passwords used to enter the enable mode. With these credentials, the system can issue CLI commands on live devices.
1) Click the Privilege Login tab.
2) Click Add to open the Privilege Login dialog box.
3) Enter the access credentials and click OK.
Repeat steps 2) and 3) to add more entries if required.
Information Tip: The system polls these credentials in order when discovering network devices. To sort the order, right-click the target entry and select Move To Top or Move To Bottom.
