Calculate Path Across vCenter Network
The system supports end-to-end path calculation across a vCenter network, and you can analyze the traffic flow between two endpoints.
- Click Path next to the search bar.
- Enter the IP address of endpoint A in the Source field and the IP address of endpoint B in the Destination field. The available gateways are auto-identified, and you can select the desired one from the Gateway list.
Tip: If Anycast Gateway is selected, detailed information will be displayed, including APIC domain, tenant, APP profile, EPG, and BD (IP). |
Tip: To change the path direction, click the icon and select the icon. By default, the system calculates two-way paths.
- Click Path to start calculating. Then you can view the diagrammed path on the map.
