Auto-Refresh a Map
With Auto-Refresh is enabled, any changes made on the map will be automatically synchronized to the current view-only map. Then users can view the latest version of the map.
Note: Auto-refresh is only available to the Maps not owned by you, i.e., you don't have editing rights to the map. |
- Open a map you don't have editing rights to the map will be in View-Only mode.
- Enable Auto Refresh.
Note: By default, Auto Refresh is disabled. - Click the
icon to configure Refresh Settings.
- Refresh All (Map & Data View)
This option means reloading the latest saved map first and then reapplying the data view last selected to the map when the map is refreshed.
- Only Refresh Data View
This option means reapplying the data view currently selected in the map when the map is refreshed.
Example: If the map owner drags and moves devices on a map to change the map layout or zoom in/out the map, the view-only map layout remains unchanged when the map is refreshed.
- Set the frequency of auto refreshing the map
Enable the check box and then specify the frequency of auto refreshing the map.
