Auto Intent Wizard
The Auto Intent Wizard provides a quick way of enabling an intent template for auto intent for end users. The description for auto intent and the profiles for organizing the auto intent are also defined via Auto Intent wizard.
In the Auto Intent Wizard, you can complete the following three steps in respective tabs:
  1. Intent Template: Select an intent, then convert the intent to an intent template.
  2. Pre-decode the installed Intent: Select a group to install the NIT, then pre-decode the intent template.
  3. Enable auto intent: Enable the intent template for Auto Intent and add it to a profile.
The initial UI of the Auto Intent Wizard is shown below:
For where to launch the Auto Intent Wizard, see Intent Replication Wizard (Where to Start)
