Annotate Runbook to Share Knowledge
The system centralizes the scattered description and annotation functions (such as the description of a Runbook or a Runbook node) in a single pane, including Runbook tags, category, author, modified time, annotation, and device qualification readiness for each node.
The centralized document pane is also available in Runbook Template when you:
- Edit a Runbook Template Document:
- Preview a Runbook Template:
