Access Credential for Telnet/SSH CLI, Smart CLI and Change Management
Specify to use the private or shared credentials for SSH/Telnet CLI access, Smart CLI access and network change management.
| Option | Description |
| Use Private Credentials and Shared Privilege Credentials (default) | Use the credentials defined in the Private CLI Settings to log in to devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode. |
| Use Private Credentials and Private Privilege Credentials | Use the credentials in the Private CLI Settings to log in to devices and then use privilege credentials defined in the Private Device Settings to enter the privileged mode. |
| Use Shared Credentials and Shared Privilege Credentials | Use the credentials defined in the Shared Device Settings to log in to devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode. |
