R12.1 Project-2025/11/05
Managing Configuration Templates
To reuse configurations for network change tasks in the future, you can predefine it as a config template. When Defining the Change Node, you can directly load a config template instead of writing commands manually.
Proceed with the following steps to create a configuration template:
  1. Click the start menu , and select  Incident & ChangeNetwork Change.
  2. In the Network Change pane, click Configuration Templates.
  3. In the Manage Configuration Templates pane, point to a folder and click the drop-down menu to select New Template.
  4. Graphical user interface, application
  5. Click Save to complete the configuration template.
