R12.1 Project-2025/11/05
Live Device Data
The following types of live device data can be retrieved for task execution in a domain:
Information Note: The available data types may differ depending on the analysis task types and device types.
  • Configuration File
  • General Data Tables, including: Route/ARP/MAC/NDP/STP.
  • NCT Table, including:
    • Azure Neighbor Relationship Table,
    • IPsec VPN table,
    • BGP All VPNv4 Advertised Route Table,
    • Cisco Coverage Summary,
    • GRE Tunnels,
    • NAT Table,
    • IPv6 Route Table,
    • BGP advertised-route table, and so on.
  • CLI Command OutputsThe outputs of the executed CLI commands.
    For example, the CLI outputs of the
    show ip bgp summary command or the show ip eigrp neighbors command.
