R12.1 Project-2025/11/05
Enable/Disable Installed Automations
To enable or to disable an intent in the Preventive Automation Manager:
- Click
, scroll down and select Preventive Automation Manager from the menu. - Navigate to the Triggered Intent tab, and check/uncheck to enable or disable installed triggered Intent (s).
Note: If the installed triggered Intent is disabled, it will not be displayed in the Execution Tree.
