Logo
R12.1 Project-2025/11/05
Approving a Network Change Task
When a network change task is created, it must be approved before implementation. Based on the way that the task creator submits the approval request, you can:
  • Approving a Network Change in NetBrain System
  • Approving a Network Change in an External System
Adding and Defining a Note Node Approving a Network Change in NetBrain System
