R12.1 Project-2025/11/05
Build L2 Topology Option
You can specify how the L2 topology is calculated:
Field/Check BoxDefault ValueDescription
Filter DHCP EntriesDisabledIf enabled, the system filters out the outdated DHCP entries and only keeps the latest IP addresses when building L2 topology.
Use all devices' MAC Table to calculate the Switch Port and Possible Switch Port in One-IP TableEnabledIf enabled, the system will use all devices' MAC Table to calculate the Switch Port and Possible Switch Port in One-IP Table.
Only save One-IP Table entries that have values in any of the Switch Port, Possible Switch Port, and DNS Name
Enabled
If enabled, the system only saves entries with switch ports, possible switch ports or DNS names in One-IP table. It helps decrease the storage size and increase the query efficiency of the One-IP table.
Information Note: Any changes to the settings will take effect from the next L2 topology calculation.
