Visualize Third-party API Data via Qapp
You can call third-party API data in the system and monitor the parsed data on a map by running a Qapp.
  1. Open a map with your interested devices.
  2. Right-click on the blank space of the map and select Run Qapp.
  3. Select the Qapp you have created in the Select Qapp dialog.
  4. Run the Qapp. Sample output is as follows:
