R12.1-2025July30
Executed via Intent Timer or Other Sources
If an Intent is executed via an Intent Timer or other sources, they are listed under this section. For example: If the device belongs to a triggered Network Intent and the flash probe of the device is not defined to trigger the NI, then the NI will be placed under Executed Via Intent Timer or Other Sources.
Note: When you click and open the specific triggered automation, the Network Intent window in view mode will appear on screen.
